- Mar 17, 2014
Look into the 18's pole lap at Atlanta.It only happening under load, sitting static it will not be found.
I thought rear steer was the location of the steering linkage; in front of the axle or the rear of the axle.
Interesting but I'm a little confused about, "front and rear wheel cambers." How do you adjust rear wheel camber on a solid axle rear end?
By welding the axle bearing housing to the tube at the desired angle.Interesting but I'm a little confused about, "front and rear wheel cambers." How do you adjust rear wheel camber on a solid axle rear end?
I guess it doesn't take much. I know they use floating axle design, does this mean that the tolerances in the axle splines are a little slack?By welding the axle bearing housing to the tube at the desired angle.
Yeah, it doesn't sound like they'd run 100,000 milesIt's hard on axles, bearings and third members. Replaced on each car after every event.
I believe you are correct!I thought rear steer was the location of the steering linkage; in front of the axle or the rear of the axle.
