DanicaFreak
2021 Big Gator winner <Green Monster>
- Feb 21, 2014
That's a pre-fuel injected, pre-individual coil pack Chevy R07 engine. The only Chevy V engine to ever have the distributor up front.
Man that engine looks good! How much does it cost?
Around 80K, assuming you can purchase one.Man that engine looks good! How much does it cost?
TRD heads ( JGR, I believe Kensths ride)
And Ford's FR9 engine
Oh, so you want to see a real one uh? here ya go, from Brad K's Fusion
For X amount of dollars, you can probably have it done.When I die, I want my casket to look like a giant TRD valve cover. I am serious.
I doubt that I have enough dollars. There are funeral homes that will do special requests. Ask around.Will you sponsor me? I won't ask again. Literally.
Hell yeah, that is an awesome idea ,I love itWhen I die, I want my casket to look like a giant TRD valve cover. I am serious.
Richard Petty said the same thing when he switched to Ford. Then he was faster than Roush for awhile.I believe Rodney Childers said the mounts on the Ford engine were lower then the Chevrolet's they were using, they had to completely re do their front suspensions. Pretty much had to replace the whole front clip on their pre built cars when they switched over.
The alloy used to construct them is called Inconel 625. The material cost alone for 1 set is approx $2000. They can be used 3 or 4 times before they’re taken out of service. The tubing is thin as in thin.What amazes me is the maximum flow and quality of the tig welds of those headers..... Built as light as possible. ....
I just want a simple funeral without the beautiful bow tie valve covers.
Just crank up a Chevy race car that has obviously raced and still has the beautiful dings. It still would have the worn tires and the residual burnt rubber perfume.
Crank it up loud, it needs to be loud, rattling the sheet metal and surroundings the perfume of the racing gas would fill the air.
It would be too loud for an eulogy. Make it a carburated modified with the long side pipes.
Then just pour me ashes slowly in the carburator slowly one early morning and let it blow the ashes into a worthy receptacle, A long and lean twirling nude supermodel.
