SBC 350 Engine
MAGICMILER
Put it out...
This happened this morning...
Everything works, now it's just elbow grease..
And the price was ridiculously low.
MAGICMILER
Put it out...
Fired it up for 1 hot dog... Not too shabby..
I was going to give it a quickie clean for a quick flip, but after a neighbor became envious , I'm going with an engine teardown & restoration , then I'll keep it. Pretty sure it's the only one like it around here...
MAGICMILER
Put it out...
Started the teardown. Not as many parts as the real thing!
Magnethead
Admin & Resident Techie
Ft Worth Tx
somebody put some work into casting the small details in like the motor mounts. I knew something was cookie with the water bridge and short headers. Thought maybe it was a mini puller engine. Friend of mine had one that looked nearly identical in his mini-puller.
Magnethead
Ft Worth Tx
MAGICMILER
Put it out...
Been busy as of late. Sanded the engine stand down, going to prime tommorow. Meanwhile, this rehab package showed up from Jegs today..
I'll be unpacking it tommorow. It's ike Christmas Eve right now..
Repainting the block tommorow. Chevy high heat Orange. Pics tommorow!
  • Like
Reactions: sdj
MAGICMILER
Put it out...
As we say in New England, it's Wicked Hot today. Managed to get the block painted, and the bottom of the engine stand.
Partially unwrapped my Christmas present from Jegs. It's just too damn hot today for much else...
Magnethead
Ft Worth Tx
Is it heavy? Other than the motor mounts not being drilled/tapped and the fuel pump oriface being solid, I'm legit wondering if it was a real block that somebody cracked a web, so they torched it apart, took a grinder to it, and you have the end result.
MAGICMILER
Put it out...
^^Nah.^^^ From what I've researched, it was a modified sand casting, using aluminum for the pour. It is Wicked light weight, stand and all weighs less than 30 lbs. The heads are bolted to the manifold,which will be amputated for cleansing soon. And the best part is these came from @aunty dive territory. British Columbia, somewhere. Took me 4 hours to track them down, and a week for expensive shipping.,but they are original to the grill.
MAGICMILER
Put it out...
Back at it today..Little dressing and some more elbow grease. Hope to have it done within, well, within some sort of time frame...!
I put key set I had laying around in as a "ignition " key...
Greg
It's the short rods that make it weigh less.
MAGICMILER
Put it out...
Some more progress today.
Hid the 1 lb..propane tank in the SUNOCO can.
Afterthought, will probably hide the propane line
in the engine stand later for a more "stealth "look.. Did a initial test burn for 20 minutes with a 20# tank..No problems...
Now., on to the food party this weekend...
MAGICMILER
Put it out...
Tough to see, but smoke really does come out of the pipes...only 2 burgers, so not alot of exhaust...
