dpkimmel2001
Today's load is a preload for someone heading to Arkansas. I wish it were me. Today's hourly for me since it's local. I hope to have a 2nd load of something today just to get in some more hours.
This load is being pushed in the external valve rather than being loaded through the dome. I don't think it will take too long as it sounds like the pump is pushing pretty fast. To do this type of load procedure the dome lid has to be propped open to relieve the pressure that would build as the product enters the tank. I can't imagine what it would be like if that step was overlooked. A huge mess and a wrecked tanker would be my guess.
Today's fun tanker fact.....
I mentioned the external valve a little earlier. There is another valve that is internal to the tanker. Primarily as a safeguard in case of rollover. If only the external valve existed, the rollover would likely tear that connection off the tanker allowing for the product to be spilled causing unknown results. The internal valve couldn't be separated from the tank in that same situation. Because there are two valves, both have to be open in order to offload. The external valve is opened with the turn of a wheel. The internal is opened with the user of hydrolics. Similar to a car jack. A handle is pumped allowing for the internal valve to be forced opened. The internal valve is held shut by a heavy spring. The valve itself resembles the push stopper drain on a bath tub.
Work calls. More on valves at a later time.
