M
Mopardh9
Put more adjustment options into the car, let the teams play with spoiler angle and springs more and other suspension components, then you will see who really has the better equipment. I think the tracks are fine, it is the car that needs be to tinkered with more.I disagree. Most 1.5's have 4 corners that are similar enough to set the car up for all 4 and roll around at top speed, barely lifting in the turns. It becomes preferred line momentum racing with less wheel work required. The easiest way to take a bit of the engineering out of the racing is to make it impossible to get a car perfect in 4 corners and require the driver to get off and on the gas to a much higher degree. Some teams will set their car up for one set of corners, while other teams make other choices. Then you'll see better closing rates and more passing opportunities.
But the heavy car is the root of many of the problems with the 'racing' today.
