Put the A/C on the window. 74 and sunny! Supposed to be warm all week. Putting it in wasn't the plan. Was supposed to be attaching retractable wheels to one of the table saws. Somehow got diverted. Need to go to Lowe's and get roll of flashing tape to finish it. Then in couple weeks will put the other in bedroom window. May wait till April for that one. Freezes my head when gets cold outside.
Of course high so far is 50 today then supposed to pour tomorrow. Boooo! But calling for 80's toward end of the week. Did go to Lowe's to get the flashing tape. They have a cheap brand that's 12 bucks roll. Noice!
Found an exercise/workout machine on Marketplace trying to talk myself out of buying. It would pretty much fill the shed. Really need to do something for exercise. Can get free gym membership but really don't want to go. Rather get something for home use.
You could always do what I do. Go for a walk. It isn't as much how fast you walk but how far. The trouble with a home exercise device is they get used hard for about a week then the next most strenuous thing you do is look for excuses nit to use it. Ever wonder why are there always home exercise equipment for sale on Craig's List or marketplace?
Almost bought the 5 sheets of siding for front 10 foot of original shed. Meh. Did buy a reciprocal...nope...rectangular...nope...reconstituted...nope...oscillating saw. That's IT! Cheap Amazon Chinesium plastic cordless that uses M18 Milwaukee battricities. I have those. Will cut the nails on the verticals supporting the overhangs. Cut the existing siding right beside the studs and yank it off. Should paint those 4x7 foot sections before the install. Maybe do it tomorrow but I doubt it. Think will wait till next month. Need to give whole thing a good scrubbing before painting. Green pond that's 20 foot away corrodes the surfaces. Corrodes? Meh. Close enough.
Thought was going to Hazzard Fright to buy a bunch of 2" casters for 2x4 foot rolling benches. They will be mounted retractable so won't be carrying weight. After little searching can get set of 12 swivel casters from Amazon cheaper than set of 4 from HF. Crazy. Ordered them, pack of 12 door hinges and 8 stainless steel 5/16" x 4 inch bolts/nuts/washers for just under 50 dollhairs!
Gonna do some things. Get the shed better organized and replace the front 10 foot of siding. Then paint, trim & caulking.
Edit 68 ish bucks. Forgot about the hinges.
Moved 20 dollar job site saw to porch, put junk Delta with blown up motor on back of truck to hopefully sell/give away, on Facebook. Really suppose need to get the 220 outlet installed and see if the new 25 year old Delta works. Man it's hard to drag around. Says Wednesday for delivery of casters and stuff. I'm typing this on phone and can't see chit. Left eye is completely screwed up. Will call Raleigh Opthalmology Monday. Not gonna wait for MyEyeDoc to screw this appointment up like last time.
You could always put carpet on the floor with a cushiony padding underneath. Be a lot easier to stand on for extended periods. It would make it difficult to drag the proposed retractable wheels on the bench but everything is a trade off. Lighting seems a wee bit sparse too. Thinking you could consider new led lighting on dimmer switches could be a nice touch. Maybe even some you can change color or better still, ones that rotate colors. Now that would really dres it up in there. Add some class.
On a more serious note, back in the day, after retirement, when I had a workshop, I place a lot of stuff on the walls and in many cases made small brackets/holders for them. Helped pass the time and making the holders gave something to do on days when weather sucked. Of course, a good sound system and collection of Merle Haggard cd's are a game changer as well.
Just trying to think of ways to assist in spending your money. :biggrin:
I have a gym membership that is great but it is more of a backup plan
Imo hiking is the greatest also a great way to socialize or tune out to some great music with a headset when alone.
Also a great way to spend time with my bride and walk the dog, nothing like fresh air.
I closed in my deck with vinyl siding and windows with vinyl trim. Installed Aluminum doors, the ceiling and walls are made up or done with shiplap boards that had the polyurethane finish prior to installation.
Probably more expensive to begin with but It was the plan to avoid painting altogether.
My workshop interrior walls and boards is painted white inside but that is only to help with the lighting or illumination. The sheet rock in the house and privacy fence is the only painting I want to worry about. I may eventually replace the fencing boards with aluminum pieces that never need to be painted.
I cut up old plastic orange juice bottles to store nuts, bolts, nails, miscellaneous fastners, etc. It is cheap and the clear material makes it is easy to organize and very visible. They also store easily on the 1x6 boards above the big cabinet style tool box.
Marketplace 3/4 plyweird. Was cull wood which is imperfect/slightly damaged/cancerous, etc...so fits my usage perfectly. Only "needed" one sheet but @ 10 bucks ea. grabbed all 5. Neighbor with new trailer needs a porch. While this isn't treated paint will make it waterproof enough.
I needed a sheet for bench tops. Now have plenty!
Have a 10ish x 12ish section of linoleum like what's on the bench. Was planning on putting it in the new section. Since I seem to constantly be dragging stuff around, that would get ripped first week. Likely just paint the floor grey. Possibly paint the interior walls white for light reflection. Need to move couple of those LED lights up in the loft on a seperate switch. Or not. Definitely need to empty the lofts and sort thru stuff.
Really need to fabricate some storage for tools. Maybe end up in the rolling dresser or vanity? I hate pegboard. Have enough to hang most of my junk I just hate dealing with it.
Have a bite on the burned up motor Delta table saw. Free & I'll help load seems to be the right price. Possible could part-out on ebay but I ain't gonna mess with it. Guy says tomorrow evening.
Casters, hinges & carriage bolts arrived. Have a guy supposed to pick-up the table saw but he's put me off twice says working late. If he bails this evening it goes to next in line. Need it gone as in the way.
Called Raleigh Ophthalmology to see if they received the referral to get my left eye torched. Nope. I think lady there is on tRump's cabinet as she doesn't answer questions just gets pizzy about you asking. This was my second time dealing with her. Been same both times. I told her to have seggs with herself. Rude? She started it! LOL.
Went and kicked the beehive at MyEyeDoc and took less than minute & half for their help to say, yep, sent March 11th and it's in their system. I can see it in their system. Immediately submitted it again and printed off a copy. Said take that to them and request the Referral Admin.
Went to Raleigh Optha website. Only contact is by phone or thru patient portal. So I scheduled an appointment for April 14th at 7:30AM! Now we wait and see what happens. Won't be remotely surprised if it gets cancelled because I jumped past the usual hoops. It's possible the referrals get kicked over to the insurance company first and that's why "they don't see it".
In fact will be very surprised if get any sort of treatment on the 14th except the phone lady beating me with a sock full of quarters.
^^^got'er did. Suspect the person I been talking to/cursing @, works in a call center. Definitely not one of the two women just dealt with. Gave them the printed referral with insurance info and in less than 5 minutes we race ready. Appointment for 14th at 7:40AM is still a go unless an earlier appointment pops up. due to a cancellation.
I may be able to see again soon! Getting tough to type without closing left eye. In truth...I couldn't type when both eyes worked.
Fact could set-up an appointment in couple days past a month, ALL BY MYSELF, is kinda odd since took 7 months to get anything done in 2023.
Should be out in/beside the shed ruining perfectly good lumber but am sitting in the recliner watching youtube. If I get the wheels on the vanity & dresser can then easily mover them so can install 220 outlets. Kinda like to have two in the shed as at some point would like to buy a mig welder. That's IF the laser eye surgery helps my vision.
It's easy to change the table saw motor to 115v which probably makes more sense. Doubt that saw gets used an hour total over next year. 90% will be 1/2" to 3/4" plywood. Decisions decisions.
Moved some stuff around. Didn't really accomplish much. Think will wait until get eye ported & polished so can see better. Everything under 6 foot is kinda vague and semi-foggy. Just pizzes me off trying to do anything. Hope they can make left eye work better.
So I never looked in this chit chat forum before today and have now stumbled upon this storage building thread. So what is the point of it? Not trying to be rude, just curious.
Sorted thru the junk in the lofts. Rearranged. Didn't throw a thing away. That lumber was most of the mess. Organized somewhat.
Attempted to assemble the retractable casters on this but struggling badly. Had one on/assembled/fabbed and but removed to better attach. Turns out either need longer bolts or maybe use some all-thread. Main issue is need to add structure to base so it doesn't break the cabinet. My depth perception is way off at arms reach.
As typing this think may do it a bit different than was. They will be used to house woodworking tools. Only time wheels will support is to roll 10-15 feet across floor.
(I know you didnt ask me but here is my two cents).
The ability to have my own simple liitle workshop plus a 6 x 12 utility trailer for my truck is one of the reasons I have not moved to a downtown address.
I would seriously enjoy a place downtown. They have the Swamp Rabbit Trail for hiking and biking, good restaurants, shops within walking distance, and festivals with free music, etc. It would be a great way to be sociable and constantly meet a lot of people.
But getting back to having a workshop, and stuff (I really wish I had enough land to justify a real tractor rather then myJohn Deere x380 which is already overkill for my needs).
I don't consider myself exceptionally skilled or good enough to make a living that way. I do my best work mainly so that it meets my wife's specs etc, but that is good because it keeps from me from building some junk that I would put up with myself.
But there is just something about having the basic tools and a lifetime of saved up fasteners to frame up and build something whenever I want to do it.
For all I spent on tools and stuff, I probably could have hired some professionals to do the work, but I am just stubborn enough to avoid that option if at all possible. It's just some old hang-up for the ego.
I don't hunt or fish, and the time working in the shop is soothing. On a good day it's where I mentally sort things out and do my best thinking.
^^^only thing different for me is, no wife or boyfriend. I didn't factor in my vision getting this bad. Hopefully they can torch it back to useable. I've looked for the newer grinder at least 6 times. No idea where I put it. Can put a thin wheel on the other. Have two grinders. Likely will buy a cordless that accepts 18v Milwaukee battery. Cordless is almost always better. Let's go poke around Amazon.
Ordered mass quantity of 3/8 self-locking nutz and fender washers. I'd bet if i ever get to organize everything i'll find that I already have same stuff just can't find it.
Need to go to Hazzard Fright and get set of punches.
Harbor Freight trip was a bust. I can't see **** under 10 feet so walking around looking for at least 30 minutes just didn't work. Never a punch or chisel was found. Their focus is now on the Icon higher dollar stuff. Whole lot or huge toolboxes. Amazon to the rescue.
Deez nutz will work. Now have to wait till Monday for the washers. Bought another pin spanner for the grinder nut. No idea where that stuff went. It's here. Somewhere.
Just received call from Raleigh Ophthalmology to verify/explain my pending cataract surgery next Tuesday. It's pretty disconcerting that the office and doctor haven't realized, they did my cataract surgery summer of 2023.
I now have a PCO in left eye. It's on the referral. That is an outpatient "simple" laser zap-zap and you are fixed. Fact they can't read the referral is just inexcusable. Did get confirmation won't need a co-pilot.
Yikes. I should have just done this at home in the shed with a laser pointer...
